Battery Storage Inverter in the PV Model
  • ajabbas
13 Mar 2017 08:44 #5232 by ajabbas
Dear SAM Support Team,
I'm using the Photvoltaic (detailed)-Residential (distributed) model in SAM 2016. My question is about the battery inverter in the model. Since the Battery storage is AC coupled in SAM 2016, is the selected PV inverter intended for the battery storage as some sort of hybrid inverter? Or the battery inverter is assumed to be included in the battery storage unit?
Most of the inverters options are not hybrid invertes. Should I input two inverters in the system design to account for the PV and battery inverters?
Thanks in advance
14 Mar 2017 05:58 #5233 by Paul Gilman
Replied by Paul Gilman on topic Battery Storage Inverter in the PV Model
For an AC-coupled battery, SAM assumes that there is separate hardware to convert the battery power from DC to AC from the PV inverter. You provide the conversion efficiency for the battery converter on the battery storage input page under "Power Converters."
  • ajabbas
14 Mar 2017 16:51 #5234 by ajabbas
Replied by ajabbas on topic Battery Storage Inverter in the PV Model
Now it is clear. Thank you so much, Paul.
