Peak power not affected when adding PV
  • AdamHolmer
02 Mar 2017 05:44 #5191 by AdamHolmer
Peak power not affected when adding PV was created by AdamHolmer
My objective is to simulate a commercial building with PV + batteries. As a start, I modelled only PV, and saw that the cost from the demand charge (kW) did not change when PV was added to the building. This is strange, because you could clearly see that the peaks from the grid were reduced in sunny months, such as in July. In July, the building load peak is 185 kW, but the power received from the grid is only 140 kW because of the PV production, when looking at the time series plots. Anyway, the demand charge of $821 is the product of 185 kW times the fee of $4.44/kW and not $140. Is there is a bug in the system that makes the grid tariff based on the residential load only? Or is the PV not connected behind but in-front of the meter?
This made me look further into how peak demand is handled in the program, and as you seen in my attachments, the data don’t seem to correlate with each other: When the battery was added, the peak demand was reduced, but the demand charge was increased, which doesn’t seem very logic to me.
Also, the data in the table seem to be wrong, as the peak demand with the system is almost zero. Here it seems to be a missmatch between the tables and the graphs, as the time series plots show a more realistic demand.
Maybe someone knows what caused this problem, and I would be very thankful for your help
02 Mar 2017 17:17 #5192 by Paul Gilman
Replied by Paul Gilman on topic Peak power not affected when adding PV
Dear Adam,
Would you mind attaching the .sam file that generated the results in those screenshots to your original post? (You should be able to do so by editing the post and adding the attachment.) Otherwise, could you email me the file?
  • AdamHolmer
03 Mar 2017 02:05 #5193 by AdamHolmer
Replied by AdamHolmer on topic Peak power not affected when adding PV
Dear Paul
Thanks for your reply - I just sent you an e-mail containing the file
Regards
Adam
