Power Tower Field Optimization
24 Apr 2012 11:03 #513
Power Tower Field Optimization was created by Paul Gilman
SAM's power tower field optimization is an implementation of the DELSOL3 model, which his described in Kistler, B. (1986). "A User's Manual for DELSOL3: A Computer Code for Calculating the Optical Performance and Optimal System Design for Solar Thermal Central Receiver Plants." Sandia Report No. SAND86-8018. (
PDF 10 MB
To briefly describe the process: DELSOL3 uses 5 different days of the year with ideal insolation conditions to approximate annual energy output, then from this calculation it determines the LCOE for the system and selects a tower height, receiver area, and field layout that minimizes LCOE. Because of the way DELSOL3 optimizes, it is not possible (within SAM) to have it design a field for a particular hour/day of the year.
- m@ie
07 May 2012 10:14 #514
by m@ie
Replied by m@ie on topic Power Tower Field Optimization
hello,
I'm trying to simulate a small tower (15 MWe) with 3 hours of storage. But I have an issue with the solar field optimization wizard : "PTGEN failed".
What input should I change (receiver diameter, tower height, heliostats width and height, distance from tower?) in order to run the wizard correctly?
Thank you for your answer,
Matthieu
Matthieu
07 May 2012 17:46 #515
Replied by Paul Gilman on topic Power Tower Field Optimization
Does the discussion in this post answer your question?
Power Tower Circular Field Optimization Wizard Crashes Units Error
