Inverter Nominal DC Voltage
  • hina
27 Feb 2023 10:11 #11961 by hina
Replied by hina on topic Inverter Nominal DC Voltage
what is Nominal DC voltage? where do we consider it? how it is different from the MPPT Inverter range?
Attachment not found
27 Feb 2023 17:02 #11962 by Paul Gilman
Replied by Paul Gilman on topic Inverter Nominal DC Voltage
The inverter's nominal DC voltage is its input voltage at design conditions. The minimum and maximum MPPT voltage are voltage limits: the inverter input voltage cannot be less than the minimum MPPT voltage or greater than the maximum MPPT voltage.
If your system design results in the array voltage exceeding the MPPT voltage limits, SAM sets the inverter input voltage to the MPPT limit, which results in MPPT voltage clipping losses, which are reported in the results.
