Min and max header flow rate
- cspchathu
11 Dec 2016 06:54 #4991
by cspchathu
Min and max header flow rate was created by cspchathu
Dear paul
I tried the exercise explained in the sam.nrel.gov/sites/default/.../sam-webinars-2014-parabolic-trough-systems.pdf .
But it does not converge. the results are attached. Also I can't understand that why we use 16 instead of 46 (=8*5.75). In the Webinar, the logic is explained. But what will be the highest value of Nsca, where we apply that logic? or is the maximum value of Nsca 16 (l'=2)?
I want to find the best solar collector which gives the best PPA(LCOE). To find that I am trying to do this exercise for other collectors too. i.e. I am considering the area of each collector in the SAM library. the excel sheet is attached here with. Then I simulate SAM file for each collector separately.
Have I done any thing wrong here?
Is there any method to find the best collector instead of the method what I am trying.
Then I tried the method explained in the "Technical Manual for the SAM Physical Trough Model,Michael J. Wagner and Paul Gilman".
The guess value calculated using Eq.2.15 (page 13) can be used as the current iteration value. But how do we decide the mass flow rate in the previous iteration, T'(loop,out) and T (loop,out) at the first iteration step. I tried to combine eq.2.10, 2.11, 2.26, and 2.13 with this. But I could not find a way. Please help me on this.
Some of SAM files, Weather data for Hambanthota, Sri Lanka and the excel sheet are attached here with.
- cspchathu
18 Dec 2016 03:45 #4992
by cspchathu
Replied by cspchathu on topic Min and max header flow rate
hello,
I prepared excel sheet to calculate minimum and maximum loop flow rate. I followed the guidance given by the webinar. Can any one check this and give your idea on this. the excel sheet is attached in the previous post,
- cspchathu
07 Jan 2017 05:16 #4993
by cspchathu
did any one check this out? can anyone help me on this?
10 Jan 2017 14:45 #4994
Replied by Paul Gilman on topic Min and max header flow rate
It is not clear what you mean by "it does not converge." The results in the spreadsheet you attached seem to make sense.
The components in SAM's libraries are not necessarily useful for determining the “best” collector and receiver to use in a given application. You should be able to get information about expected optical errors, tracking errors, and other properties from the equipment manufacturers. They will also know the cost, which is obviously going to be one of the most important factors. The options in the library are useful as a reasonable starting point. From there you can understand general trough behavior as weather conditions, TES, and power cycle designs change and explore how changing design field parameters can affect performance.
- cspchathu
07 Aug 2017 21:25 #4995
by cspchathu
I did a parametric analysis using SM, NFS (nos of field subsections), PPA price,and TES. a summary of the results are attached herewith. My understanding is, if the NFS, SM, and TES are not changed, the LCOE cannot be changed. am I correct? but according to the results, it changes when the PPA price changes. Please give me the reason/s. this can happen due to involving of many iterations. is that the reason?
08 Aug 2017 15:49 #4996
If you have chosen the Specify PPA price option on the Financial Parameters input page, the LCOE is likely to change with the PPA price, even if you do not change any other inputs. That depends on your other assumptions. For example, if you use the sculpted debt option to calculate the size of debt based on the cash available for debt service, then the debt costs will vary with the PPA price because available cash depends on revenue. Also income tax liability is included in the LCOE calculation, and that depends on revenue.
If you use the Debt percent option for debt sizing, set all reserve accounts to zero, set state and federal income tax to zero, and remove any production-based incentives, then you should see that the LCOE remains constant as you vary the PPA price.
