Calculation of peak demand
- pmanson
08 Dec 2016 15:33 #4988
by pmanson
Calculation of peak demand was created by pmanson
A follow-up to my question in today's webinar: If we use hourly weather data, so the PV simulation is hourly, but our electric load data is quarter-hourly, does SAM look at every 15-minute interval and calculate:
[electric load for the 15-minute period] - [(energy generated in that hour)/4] = demand for that period
and then find the largest value and use it as the peak demand for the month? If not, how does it calculate peak demand in that case?
09 Dec 2016 09:50 #4989
Replied by Paul Gilman on topic Calculation of peak demand
SAM requires that the time step of the data in the weather file and load data be the same, so you would need 15-minute weather data for your analysis.
If you only have an hourly weather file, you can use the procedure described in the following post to convert it:
sam.nrel.gov/node/72606
Note that 30-minute weather data is available from the NREL NSRDB when you download it from the NSRDB website:
nsrdb.nrel.gov/nsrdb-viewer
- pmanson
11 Dec 2016 16:41 #4990
by pmanson
Replied by pmanson on topic Calculation of peak demand
Got it, thanks for the reply.
