Simulation of parabolic trough CSP plant with steam/water as HTF
- lucas_salvalaio
18 Nov 2016 08:05 #4943
by lucas_salvalaio
Simulation of parabolic trough CSP plant with steam/water as HTF was created by lucas_salvalaio
I am trying to simulate a trough parabolic CSP plant with water/steam as HTF using SAM 2016.3.14 version. I am considering taken receiver inlet and outlet temperature as 250 ºC and 335 ºC respectively. Is there a CSV file with required values: temperature, specific heat, density, viscosity, kinematic viscosity, conductivity, and enthalpy of HTF? Your kind response is highly anticipated.
My best regards.
My best regards.
18 Nov 2016 16:19 #4944
Replied by Paul Gilman on topic Simulation of parabolic trough CSP plant with steam/water as HTF
Dear Lucas,
Both of SAM's parabolic trough models are for solar fields with oil or salt as the heat transfer fluid.
The linear Fresnel direct steam model is for a linear collector with direct steam as the heat transfer fluid. You may be able to use that model for your application.
- lucas_salvalaio
19 Nov 2016 12:30 #4945
by lucas_salvalaio
Replied by lucas_salvalaio on topic Simulation of parabolic trough CSP plant with steam/water as HTF
Hello, Paul.
Thanks for your advice. However, I'll use the power tower direct steam model for my application. I would like to suggest the update of the parabolic trough direct steam model too in the new version of the SAM.
Lucas.
Lucas.
