No simulation result with Ubuntu 16.10
- Pierre Blanche
16 Nov 2016 14:51 #4940
by Pierre Blanche
No simulation result with Ubuntu 16.10 was created by Pierre Blanche
I installed sam-linux-2016-3-14-r4 on a Ubuntu 16.10 machine.
The software opens, I can select a model and change the parameters.
However, when clicking the Simulate button, a process bar appears and disappears but the main windows still shows the system parameters. No graph, no results.
The error message in the terminal is:
(sam.bin:7973): Gtk-CRITICAL **: IA__gtk_range_set_range: assertion 'min < max' failed
Can you help?
I installed the windows version on the same machine running wine and it works.
Pierre
Can you help?
Pierre
16 Nov 2016 16:03 #4941
Replied by Paul Gilman on topic No simulation result with Ubuntu 16.10
Dear Pierre,
Please try the suggestions in this post, and let me know if you continue to have trouble:
sam.nrel.gov/node/69509
- Angus King
18 Nov 2016 01:51 #4942
by Angus King
Replied by Angus King on topic No simulation result with Ubuntu 16.10
Paul (and Pierre)
I still encounter the problems I've had previously with the Linux version so use the Windows version with Wine (also on Ubuntu 16.10). I occasionally check the newer versions but accept having to use the Windows version for the moment.
Angus
Angus
