Stand-alone usage of HCE module
  • solarjoe
10 Nov 2016 03:09 #4916 by solarjoe
Stand-alone usage of HCE module was created by solarjoe
we need to make a sensitivity analysis on different HCE parameters.
Is it somehow possible to use HCE module of the PT physical model
for that, e.g. by using the SDK?
So we wouldn't have to implement the thermal resistance network.
Kind regards,
Joe
  • solarjoe
10 Nov 2016 06:47 #4917 by solarjoe
Replied by solarjoe on topic Stand-alone usage of HCE module
I saw that the HCE module is derived from Forristall's EES code.
So this would be one possibility, but it would be more convenient
for us to use the SDK (Python, Matlab).
  • solarjoe
11 Nov 2016 05:29 #4918 by solarjoe
I am trying to get Forristall's EES code to work, but it is a bit annoying to format
the code copied from the PDF (line breaks, indention).
Also the interpolation datasets used by INTERPOLATE('...') are not available.
Do you know if it is possible to download the *.ees file somewhere or could you provide it to me?
This would be very helpful!
  • solarjoe
15 Nov 2016 08:09 #4919 by solarjoe
*Bump*
16 Nov 2016 15:30 #4920 by Paul Gilman
Replied by Paul Gilman on topic Stand-alone usage of HCE module
The SDK provides access to the system models (physical trough, molten salt power tower, etc.) as a whole, so you cannot use it to access individual components such as the HCE.
I will follow up on your questions about the EES model.
