Downloaded Wind Resource Data Missing Pressure Data
  • Matt Steen
11 Oct 2016 12:10 #4817 by Matt Steen
Using a wind resource file downloaded from the WIND Toolkit in SAM does not seem to work in 2016.3.14. It appears that the pressure column is missing data since every row is 0 atm. This results in zero kWh production. I've also noticed that there are more than 8765 rows in the downloaded data compared to the representative typical wind resource files.
Matt Steen
Building Performance Engineer
Ambient Energy
  • Matt Steen
11 Oct 2016 13:02 #4818 by Matt Steen
As a workaround, I used the pressure data from a corresponding TMY3 file ( energyplus.net/weather ) by opening the EPW in Elements ( bigladdersoftware.com/projects/elements/ ), copying the pressure column, and pasting it into the SRW file.
12 Oct 2016 15:15 #4819 by Paul Gilman
Replied by Paul Gilman on topic Downloaded Wind Resource Data Missing Pressure Data
Dear Matt,
Thank you for pointing out this issue. We are investigating, and will the fix the problem as soon as we can.
  • KateDoubleday
27 Oct 2016 08:09 #4820 by KateDoubleday
Replied by KateDoubleday on topic Downloaded Wind Resource Data Missing Pressure Data
Is there any update on this problem? I am also getting 0 kW output when using data from the WIND Toolkit.
Kate Doubleday
  • justaskingonequestion
15 Nov 2016 12:16 #4821 by justaskingonequestion
Replied by justaskingonequestion on topic Downloaded Wind Resource Data Missing Pressure Data
Is there an update?
The problem still persists for several regions such as upper Texas above Amarillo while unaffected at certain regions such as below it.
16 Nov 2016 15:33 #4822 by Paul Gilman
Hi all,
There is a problem with the data for 2012. As a workaround for now, you can choose a different year to download a complete weather file.
The WIND Toolkit team is still working to resolve this issue. I will post more here when I learn more.
