Electricity Rates
  • stumpyd123
04 Aug 2016 18:10 #4657 by stumpyd123
Electricity Rates was created by stumpyd123
I have been able to figure out just about everything I need to in SAM, but I still find the electricity rates page baffling for more complex rate structures.
Can you please show me how to input this rate structure?
Summer Demand Charges
December, January, February from 10 AM to 8 PM, weekdays only
Demand charges above 20 kw cost $55/kW
Off Peak Demand Charges
All the rest of the year
Demand charges above 40 kW cost $13/kW
Energy Charges
From 10 AM to 8 PM on weekdays, the power costs $0.13 / kWh
All other times, power costs $0.08 / kWh
09 Aug 2016 12:29 #4658 by Paul Gilman
Replied by Paul Gilman on topic Electricity Rates
Here are screenshots showing the demand charges and energy charges you describe (I moved the schedules in the image to fit here):
  • stumpyd123
18 Aug 2016 15:07 #4659 by stumpyd123
Replied by stumpyd123 on topic Electricity Rates
Thanks Paul. What do you do with the table under demand charges "Demand Rates by Month with Optional Tiers"?
19 Aug 2016 14:37 #4660 by Paul Gilman
That table is for a demand charge that applies to the peak demand in each month without time-of-use periods. You can set the $/kW charge for each month in that table to zero to remove that from your analysis. (You could also change "Number of entries" to 1, and then set the single $/kW charge to zero.)
  • stumpyd123
22 Aug 2016 15:34 #4661 by stumpyd123
Thanks.
