HCE and SCA Types reference
  • Croisfelt
10 Jul 2016 23:54 #4606 by Croisfelt
HCE and SCA Types reference was created by Croisfelt
During some analysis with our PTC (physical) models, when configuring different HCE types among loop's nodes of the Solar Field, the software takes in its calculus different SCA Optical Efficiency values, even if all the nodes' SCAs are set as the same type.
It is possible that the software is mistakenly using HCE Type parameter also as SCA Type reference for each node. In each node, HCE performance depends on SCA optical efficiency (refer to section 2.4.1 of 'Technical Manual for SAM Physical Trough Model' document).
  • Croisfelt
11 Jul 2016 02:13 #4607 by Croisfelt
Replied by Croisfelt on topic HCE and SCA Types reference
Sent more clarifications by e-mail.
