How can I simulate a PV design with not the same number of modules in each string?
- eddy9305
25 Apr 2016 09:21 #4329
by eddy9305
How can I simulate a PV design with not the same number of modules in each string? was created by eddy9305
Is there any way to simulate a PV design with not the same number of modules in each string? The design has 3 subarrays (with 1 inverter per subarray), like this:
*Subarray 1 (2 strings with 11 modules)
*Subarray 2 (2 strings with 11 modules)
*Subarray 3 (1 string with 10 modules)
Something like the uploaded figure.
Thanks.
Regards from México.
Thanks.
25 Apr 2016 12:05 - 18 May 2023 09:32 #4330
Replied by Paul Gilman on topic How can I simulate a PV design with not the same number of modules in each string?
SAM assumes that all modules in the PV array are connected either to a single inverter or to a bank of identical inverters with a single input. For that reason, all subarrays must have the same number of modules per string to maintain a single voltage level.
You could use the "Combine Cases" macro to model your system, or you could model Subarray 3 with 11 modules. To use the macro, you would create a separate case for each subarray, and a fourth case using the generic system model for the financial inputs. See the instructions provided with the macro for details.
UPDATE: As of SAM 2021.12.02, the Combine Cases macro is replaced by the Calculate generation profiles and nameplate capacity from open cases option on the Power Plant page for the Generic System model and Generic Battery model. See the SAM YouTube channel for a short tutorial .
Last edit: 18 May 2023 09:32 by Paul Gilman.
- eddy9305
25 Apr 2016 12:20 #4331
by eddy9305
Replied by eddy9305 on topic How can I simulate a PV design with not the same number of modules in each string?
Thank you for your answer. I'll try that macro and see the results.
Regards.
Regards.
10 Aug 2020 09:28 #8538
As of SAM 2018.11.11, the Detailed Photovoltaic model supports inverters with up to four MPPT inputs, which means that you can model a system with up to four subarrays with different string lengths without using the Combine Cases macro. Each string operates at its own voltage, so voltage clipping losses are modeled in a more realistic way than in previous versions of SAM.
