Auto-Generate Reports Using SamUL?
  • spharris
30 Mar 2012 14:43 #434 by spharris
Auto-Generate Reports Using SamUL? was created by spharris
I'm working on a SamUL script that can take an input file to run a series of PV simulations and produce some outputs, one of which (hopefully) is a PDF report using the report generator. Is there a function to do this using a pre-existing template that I've created?
30 Mar 2012 16:32 #435 by Paul Gilman
Replied by Paul Gilman on topic Auto-Generate Reports Using SamUL?
There are no SamUL functions to control SAM's report generator. However, you can use SamUL script to write SAM data to a text file with HTML or other markup that you could convert to PDF.
For example, you could use Markdown and Pandoc to generate a PDF files from a text file generated by SamUL.
Attached is a SAM file with a SamUL script that illustrates a different approach using HTML and CSS. The script generates an HTML file with tables and graphs of SAM data. The HTML requires the attached CSS file for formatting.
SAM's report generator is limited in functionality and difficult to use, even with the improvements in SAM Beta 2012.3.26 -- we're working on some different ideas for improving it and would appreciate any suggestions.
