Power generated higher than nameplate capacity
  • taina
08 Apr 2016 11:11 #4247 by taina
I am making some simulations using all SAM's default values, and the wind resource from Northwestern TX - flat lands (NREL AWS Truepower representative file).
I have noticed that sometimes, the power generated by system (kW) is higher than the system nameplate capacity (kW), and I wonder if the power shouldn't be always smaller or equal than the nameplate capacity.
Many thanks!
Taina
08 Apr 2016 15:56 #4248 by Paul Gilman
Replied by Paul Gilman on topic Power generated higher than nameplate capacity
Dear Taina,
The nameplate capacity is just that, a name, or rated capacity. The actual output of the turbine depends on the power curve, which may exceed the nameplate capacity under some conditions.
However, the wind turbine output should not exceed its nameplate capacity by very much.
