SAM 2016.3.14 Runs much slower than previous versions
  • NavidS
05 Apr 2016 07:47 #4237 by NavidS
I started using the new version of SAM (2016.3.14) for PV and noticed the run time is much longer than before.
Is there anything I can do to resolve the issue?
Navid
05 Apr 2016 14:12 #4238 by Paul Gilman
Dear Navid,
The PV model itself should not run slower in SAM 2016.3.14 than it did in older versions. The 3D Shade Calculator in the new version is slower because it is making new diffuse shading calculations, and potentially calculating subarray shading loss values from a set of string loss values.
Would you mind [url=mailto:sam.support@nrel.gov?subject=PV%20model%20running%20slowly t=_self]emailing me[/url] a copy of a .sam file that is running slowly so I can run some tests on it?
  • NavidS
12 Apr 2016 07:08 #4239 by NavidS
Thanks for your response. It seems installing the update resolved the issue.
Navid
