Annual water usage CSP
- Tomasso135
02 Mar 2016 10:07 #4129
by Tomasso135
Annual water usage CSP was created by Tomasso135
Hi NREL-Team, hi Paul,
the help file outlines that SAM reports the 'annual water usage' for a CSP system including cooling and washing water usage.
I cannot find this parameter in the SAM simulation results. Can you help me? I only found 'Cooling water makeup flow rate | (kg/hr)'
Thanks in advance
Thomas
Thanks in advance
Thomas
04 Mar 2016 10:51 #4130
Replied by Paul Gilman on topic Annual water usage CSP
Dear Thomas,
You are correct. Older versions of SAM reported an annual water usage value in cubic meters, but the current version of SAM only reports the hourly mass flow rate. We did not update the description in Help to reflect that change.
I will see if we can put that metric back in the results for a future version.
