solar water heater
- ahmed abdelrazik
23 Feb 2016 14:38 #4109
by ahmed abdelrazik
solar water heater was created by ahmed abdelrazik
dear sir,
how to choose type of collector used for solar hot water if it's used for a large system?
and if the collector known i need to know which one used?
best regards,
Ahmed Emadeldin
best regards,
Ahmed Emadeldin
25 Feb 2016 09:24 #4110
Replied by Paul Gilman on topic solar water heater
Dear Ahmed,
Choose the collector type on the Solar Water Heating input page. You can either choose a collector from the library (the largest collectors in the library are 12.1 square meters), or you can enter your own parameters for any collector not in the library.
The total size of the system is determined by the collector area and number of collectors. You can design a large system with many small collectors, or with fewer large collectors.
It is up to you to determine what collector to use based on your design.
