Solar heating in SAM
  • Zhiyong Tian
16 Dec 2015 03:32 #3972 by Zhiyong Tian
Solar heating in SAM was created by Zhiyong Tian
DO the SAM have some solutions for solar district heating? My Phd project focuses on Large scale PTC collector field for district heating.
On the other hand, do the NREL have some plan to add the district heating to the SAM?
Maybe I want to have a visit to NREL about the application of PTC in solar heating field.
Best regards
Tian
16 Dec 2015 12:25 #3973 by Paul Gilman
Replied by Paul Gilman on topic Solar heating in SAM
Dear Tian,
SAM's solar water heating model is designed to model rooftop solar water heating systems that reduce the load of a conventional electric water heater. The financial model assumes that the value of solar energy is equal to the reduction in the building's electricity bill.
However, there is no limitation on the size of the system or load, so you may be able to use it for your district heating application.
For information about visiting NREL please see these websites:
www.nrel.gov/about/visiting-nrel.html
www.nrel.gov/careers/internships.html
  • Zhiyong Tian
18 Dec 2015 03:58 #3974 by Zhiyong Tian
Replied by Zhiyong Tian on topic Solar heating in SAM
Thanks a lot for your reply.Maybe SAM's solar water heating model focus on flat plane collector. The solar filed in my project is Large scale parabolic trough collector field.( about 10000 ?).I will check the Sam user guide carefully.
Thanks again.
Best regards
Tian
18 Dec 2015 10:11 #3975 by Paul Gilman
Dear Tian,
SAM's solar water heating model is for flat-plate or tubular collectors. It does not model parabolic trough collectors.
You may be able to use the physical trough model for your project. Please see this post for details about using the trough model for a thermal application:
sam.nrel.gov/node/69067
  • Zhiyong Tian
04 Jan 2016 05:18 #3976 by Zhiyong Tian
Thanks a lot.I will check it.
Zhiyong Tian
