ISCC simulation
- Yuji Saito
13 Dec 2015 10:28 #3964
by Yuji Saito
ISCC simulation was created by Yuji Saito
Hello. Could you advise if the current latest version can simulate ISCC application?
14 Dec 2015 12:48 #3965
Replied by Paul Gilman on topic ISCC simulation
Dear Yuji,
Yes. Integrated Solar Combined Cycle is available as a performance model when you first create a case in SAM 2015.6.30 -- you should see it at the bottom of the list of performance models. You can ignore the error message about default values when you create a case.
- Javier Rodriguez
07 Mar 2016 02:06 #3966
by Javier Rodriguez
Replied by Javier Rodriguez on topic ISCC simulation
Dear Paul
I have downloaded SAM 2015.6.30. I don´t find the option to simulate an ISCCS. Is it not included in this version? ¿Which is the version that includes this model?
Best regards
Best regards
07 Mar 2016 09:55 #3967
Dear Javier,
Please be sure you are using the latest updated version of SAM 2015.6.30. ISCC was not part of the original release, but was added as a revision to the original release.
I would recommend downloading the current version from the Downloads page, then uninstall your current installation of SAM 2015.6.30 and install the latest version. SAM should automatically offer to update, so you could instead update your version by allowing it to update when you start the software.
