PV Shading Module Dimensions
22 Mar 2012 16:50 #402 by Paul Gilman
PV Shading Module Dimensions was created by Paul Gilman
The PV model's self shading calculator allows you to enter the module's width, and calculates the module length using the following equation:
Module Length = Module Area / Module Width
Where Module Area is the value from the Module page.
You should be able to find the width measurement for a given module on the manufacturer's data sheet.
