Maximum numbers of loops
  • Tomasso135
20 Oct 2015 04:14 #3839 by Tomasso135
Maximum numbers of loops was created by Tomasso135
what is the maximum numbers of loops in parallel conection to the header? I assume one loop = 4 SCA (Eurotrough ET150).
Is a number of 50 or 60 loops on one site of the header (means on both sides of the header in total 100 or rather 120 loops) in one subfield realisic? Can you give me a hint?
Thank you very much in advance.
Thomas
20 Oct 2015 15:01 #3840 by Paul Gilman
Replied by Paul Gilman on topic Maximum numbers of loops
Dear Thomas,
Is your question about physical design limitations or about SAM's physical trough model? SAM does not have information about the physical connections between headers and SCA loops.
  • Tomasso135
21 Oct 2015 08:14 #3841 by Tomasso135
Replied by Tomasso135 on topic Maximum numbers of loops
Yes it is also a question about physical design limitations. Or even better do you have information how many loops are parallel connected on one header in real projects? I cannot get any information about that fact. Or do you have a publication about this theme?
For simulation it is important for example for the choice: How many subfields are necessary?
Greetings
Thomas
