Modeling IAM losses in SAM
  • gonecrawfishin
25 Apr 2016 06:52 #3827 by gonecrawfishin
Replied by gonecrawfishin on topic Modeling IAM losses in SAM
Does this mean that I cannot input IAM parameters unique to my specific module? The CEC model in SAM uses the same IAM equation for all PV modules?
25 Apr 2016 12:12 #3828 by Paul Gilman
Replied by Paul Gilman on topic Modeling IAM losses in SAM
That is correct. The CEC photovoltaic module model in SAM uses the same set of IAM coefficients for all modules.
SAM's IEC 61853 module model allows you to enter your own set of IAM coefficients.
  • willhobbs
30 May 2024 15:35 #13220 by willhobbs
Replied by willhobbs on topic Modeling IAM losses in SAM
I've been searching around on IAM stuff (see github.com/NREL/SAM/issues/1781 and  github.com/NREL/SAM/issues/326 ) and came across this old forum thread.
Should that be air mass modifier (spectral response) coefficients? For IAM, I only see the drop-down for selecting from two module covers (AR coating and standard glass).
Thanks!
Will
03 Jun 2024 14:13 - 03 Jun 2024 14:14 #13229 by Paul Gilman
Hi Will,
You are correct. The IEC 68153 Single Diode model has inputs for the air mass modifiers, which are coefficients to the Sandia polynomial model for air mass described in King, D.L.; Gonzalez, S.; Galbraith, G.M.; and Boyson, W.E. (2007). "Performance Model for Grid Connected Inverters." 47 pp.; Sandia Report No. 2007-5036. ( PDF 1.3 MB ).
It does not have inputs for IAM coefficients.
Last edit: 03 Jun 2024 14:14 by Paul Gilman.
