Limitations of 3D shade modeling for PV systems
- mrogers
22 Sep 2015 17:22 #3737
by mrogers
Limitations of 3D shade modeling for PV systems was created by mrogers
I'm trying to model performance of a flat plate PV system that is shaded by a wall to the southeast. The simulation is showing poorer performance than I expected.
I see a note in the "Add active surface objects" help section that says the active surface object is intended to represent a small rooftop array or subarray and that it is not designed to represent a row in a large roof or ground mounted array that has many rows.
In this case the modeled array is 3 rows of 14 modules and I now have the first row as one active element and is subarray 1. Rows 2 and 3 are both part of subarray 2.
If I'm doing this wrong, any advice on how it should be modeled for accurate results?
23 Sep 2015 10:54 #3738
Replied by Paul Gilman on topic Limitations of 3D shade modeling for PV systems
Would you mind [url=mailto:sam.support@nrel.gov?subject=SAM%20File%20with%20Shading%20Scene%20from%20Support%20Forum t=_self]emailing me a copy [/url]of the .sam file with your shading scene? I'll take a look and see if anything seems wrong.
