Utility rates
  • patngesh
05 Aug 2015 06:37 #3600 by patngesh
Utility rates was created by patngesh
Why are the variables flat buy/sell rate not available in parametric and stochastic analysis?
Second,I would like to model a rooftop PV system with unreliable grid but no battery.What is the best way to incorporate this?
Regards
05 Aug 2015 11:40 #3601 by Paul Gilman
Replied by Paul Gilman on topic Utility rates
The flat rates should be available for parametric and stochastic simulations -- that is an oversight on our part. We will fix that in the next version of SAM.
  1. In the meantime, follow these instructions to replace the user interface file for the flat rate input variables:
  2. Download the user interface file for the third party ownership financial parameters page ( UI 4.77 KB ).
  3. If SAM is running, close it.
  4. Replace the file with the same name in your SAM installation: /runtime/ui/Utility Rate - Flat.ui
  5.   In Windows, by default, the file is in C:/SAM/2015.6.30/runtime/ui.
  6.   In OS X, to find the file, start the Finder, and control-click the SAM app to show package contents and find the file underContents.
  7. Start SAM, and create or open a residential or commercial. You should now see the variables in the list of input variables for parametric and stochastic simulations.
05 Aug 2015 11:43 #3602 by Paul Gilman
As for modeling unreliable grid, SAM assumes that the grid is always available to deliver power when the renewable energy system cannot meet all or part of the load. It is not possible to model an unreliable grid with SAM.
  • patngesh
05 Aug 2015 12:30 #3603 by patngesh
Replied by patngesh on topic Utility rates
Thanks for the feedback.
