Modeling Rates With Demand Ratchets
  • clarknd
27 Jul 2015 16:17 #3578 by clarknd
Modeling Rates With Demand Ratchets was created by clarknd
Is there a workaround method for calculating demand ratchets within SAM?
Best,
Nathan
28 Jul 2015 10:12 #3579 by Paul Gilman
Replied by Paul Gilman on topic Modeling Rates With Demand Ratchets
Hi Nathan,
SAM does not explicitly model demand ratchets. From my research on the subject, it looks like there are a few different ways they can work. How does the demand ratchet you would like to model work?
  • clarknd
28 Jul 2015 11:22 #3580 by clarknd
Replied by clarknd on topic Modeling Rates With Demand Ratchets
Paul,
It is quite a simple calaculation which is why i'm a bit suprised it hasn't been incorporated into SAM yet. But basically a 100% demand ratchet over a 12 month rolling period would look at a annual peak and then charge the customer their demand portion by that amount for each month.
Or in other words, if annual peak demand was 100 kW and the demand charge was $10/kW then the customer's annual demand charge would simply be (100kW)*($10/kW)*(12) = $12,000.
Using ratchets lower than 100%, 90% for example, sets the annual max to 90% distributed to each month's demand charge. The exception to this is if that month's actual demand is greater than the 90% of the annual peak. In that case the actual month's peak demand is used.
28 Jul 2015 12:16 #3581 by Paul Gilman
Thanks for the explanation. We'll look into implementing that for a future version.
