Battery Storage in a "sell all" scenario
  • silvaw@u-renew.com
08 Jul 2015 10:02 #3504 by silvaw@u-renew.com
Battery Storage in a "sell all" scenario was created by silvaw@u-renew.com
We are trying to model a PV+Storage in a sell all peak shaving application on a utility PPA. We have a 2 hour window to sell at a high rate, and the rest of the time at a low rate. We would like to charge the batteries from PV and discharge to grid in those peak windows.
The commercial model will not discharge the battery to the grid above the minimal PV plant load. Also if a large load is included to try to simulate, it appears to serve load first from the PV before charging the batteries. We do not want to charge batteries from the grid.
Can you recommend a way to model this scenario?
  • ndiorio
08 Jul 2015 14:06 #3505 by ndiorio
Replied by ndiorio on topic Battery Storage in a "sell all" scenario
The battery model we have assumes a Residential or Commercial case where there is some electric load to meet with PV+Battery. SAM can sell excess PV to the grid in these scenarios, but the current dispatch controller for the battery does not support selling battery power to the grid.
I could see where you would want to sell every bit of power from PV and batteries during a peak period, and then charge the batteries in off-peak periods from PV. It is possible we will add the option to dispatch battery to the grid later on. Right now however, the battery will not discharge beyond the amount required to serve the load. There is no mechanism to sell battery power exclusively to the grid. If there was, I would recommend zeroing out the load such that any PV or battery power export would go to the grid.
You can disable charging of batteries from the grid in the dispatch controller by unchecking any boxes under the column "Charge from grid".
Thank you for describing your use case, we will be continuing to add features to improve the flexibility of the model.
Nick DiOrio
