TES energy for parabolic trough with molten salt
- domenico mazzei
05 Mar 2015 02:31 - 15 Sep 2022 11:16 #3123
by domenico mazzei
TES energy for parabolic trough with molten salt was created by domenico mazzei
Thanks for your reply regarding the issue of the linear fresnel model. I would like to submit a new question on TES energy for a parabolic trough with molten salt.
The problem is related to the TES thermal capacity. This is the energy that must be stored in TES to operate the plant for the "Full load hours of TES" without sun. This means that the dump of energy should occur only when the maximum TES capacity is reached.
I create a new CSP Parabolic trough (physical), no financial model, using Hitec Solar Salt in the range of temperature of 290 and 540°C as heat transfer fluid in the solar field. The design gross output is 55 MWe (estimated gross to net conversion factor of 0.9), with a rated cycle conversion efficiency of 0.41. The TES has 6 hr of full load, with a capacity of 805 MWht. The tank height is 10 m with 1 m of minimum fluid level, and a tank diameter of 23 m.
After calculation I made the energy balance in each part of the plant (Solar field, TES and Power block) in order to evaluate the related efficiencies and also to use the thermal energy for the "Parasitic thermal field freeze protection" instead of electricity as done in SAM and then calculate the effective electricity production.
I found a strange behaviour of the energy stored in TES. I reported in attach the annual graph of the energy stored and of the energy dumped. As we can see the maximum value of the thermal energy stored is about 670 MWht, instead of 805 MWht, -16.8%.
I think that this could depend on the calculation of the storage volume. The formula 4.2 of pag. 81 of SAM manual, calculates the volume associated only with the TES thermal capacity and it isn’t the total TES volume included the "dead volume". In the file "sam_mw_trough_Type251.f90", the maximum HTF volume is calculated as :
vol_max = vol*(1.-h_min/h) ![m3] Maximum HTF volume among all tanks
and then is reduced by the ratio h_min/h, in this case of 10%.
I reduced the minimum height of .1 m, the results are in figure 2. In this case the maximum TES energy increases above 800 MWht.
I attach also the comparison for the 25 of May of the TES energy and of the storage volume considering only the volume above the minimum level.
Furthermore I think that in the formula 4.2, in evaluating the volume should be used the density of the hot tank instead of the average density. During the discharge phase there is a transfer of mass from the hot tank via the SG to the cold tank, so the specific volume of the storage should be :
V = 1000/(cp,av*(Tsf,out – Tsf,in))*3600/rho,ht = 5.44 m3/MWht
SAM calculates a value of 5.21 m3/MWht.
I would like to know what do you think about these consideration.
Best regards
Domenico
Best regards
Domenico
Last edit: 15 Sep 2022 11:16 by Paul Gilman.
12 Mar 2015 14:39 - 28 Dec 2020 11:32 #3124
Replied by Paul Gilman on topic TES energy for parabolic trough with molten salt
Dear Domenico,
You are correct that the storage sizing calculations in the UI do not consider the user input Tank fluid min height. As such, the hours of TES in the simulation results may be slightly less than the input value of Full load hours of TES.
Also note that the sizing calculations consider the Heat exchanger derate to reflect the fact that the power cycle operating from storage will be less efficient due to the lower inlet temperatures caused by the heat exchanger.
Your point about using the lowest density (the density at the highest temperature) to size the tanks is valid, but the default Solar Salt's density does not vary significantly over its operating range so the effect is minimal.
We may consider improving the storage sizing calculations for the next release, but it may not be a priority because of the uncertainty inherent in the sizing equations. The relationship between tank size and full load hours of TES will vary depending on the solar field and power cycle design parameters and actual performance during operation. You can always adjust the Full load hours of TES based on the simulation results to achieve an optimal storage capacity.
Last edit: 28 Dec 2020 11:32 by Paul Gilman.
- Louw
20 Dec 2020 09:05 #9131
by Louw
Replied by Louw on topic TES energy for parabolic trough with molten salt
Dear Paul
I have a question with regards to the TES system for the physical parabolic trough model.
When I compare the output statistics "TES charge thermal power", "TES thermal losses" and "TES discharge thermal power" (the cumulative values, which would be the total energy), I observe that the cumulative charge thermal power - losses >> discharge thermal power.
This tells me that there is some energy, in addition to losses, that is not being discharged, but instead is withheld? To my knowledge, an energy balance says that the energy discharged should be equal to the energy accumulated during charge less the energy lost. According to the balance, more energy should then be discharged.
As an example, for 5 hours of storage I get:
- TES charge thermal power (cumulative) = 354275 MWh
- TES thermal losses (cumulative) = 8412 MWh
- TES discharge thermal power (cumulative) = 344021 MWh
Then, 354275 - 8412 = 345863 - 344021 = 1842 MWh withheld?
Is there perhaps some physical constraint which prevents all the charged energy, less losses, to be discharged?
I look forward to hearing from you.
Best,
Louw
Best,
Louw
11 Jan 2021 12:11 #9172
Hi Louw,
The charge and discharge outputs are outcomes of the model’s internal energy and mass balances, and the convergence on those balances only solve to a certain tolerance. In our tests, we calculate about 0.5% when we divide his "excess: energy from the total
charge value you show. That is consistent with our expectations of the model's accuracy and the hourly output "relative energy balance error" that somewhat corresponds to the solved convergence tolerance. A similar analysis of results from the default Physical trough model is about 0.1%, most likely because the default trough case more annual generation.
