simulations on modified weather data
- besakkimuthu
05 Feb 2015 07:34 #3037
by besakkimuthu
simulations on modified weather data was created by besakkimuthu
Hello
I would like to run a simulation on a weather file of my own.
But it will not have 8760 hourly values.
I would like to run a simulation on weather data for a particular week of the year.
I have not been able to run this simulation successfully so far.
Is it possible to run such simulations for particular periods of time alone on SAM?
I appreciate any help on this question.
Thank you
Thank you
05 Feb 2015 10:54 #3038
Replied by Paul Gilman on topic simulations on modified weather data
No. SAM requires a full year's worth of weather data, so it is not possible to run a simulation over shorter periods.
If you try experimenting with a weather file that contains only one week of data (with dummy data for all other hours of the year), keep in mind that SAM uses the row number to determine the time of day for sun angle calculations. I am not suggesting that this approach will generate accurate results.
- besakkimuthu
09 Feb 2015 07:10 #3039
by besakkimuthu
Replied by besakkimuthu on topic simulations on modified weather data
Thank you
