Heliostat Field Looks Incorrect in PySAM (SolarPILOT Optimization)
- Ricardo
                24 Jan 2025 14:19                #13834
        by Ricardo
        Heliostat Field Looks Incorrect in PySAM (SolarPILOT Optimization) was created by Ricardo
I am trying to create a scenario slightly different from the default configuration of SAM for CSP Tower Molten Salt without a financial model (a.k.a. "No financial" in PySAM). For this, I used the attached Python script.The problem arises when I simulate the scenario and plot the heliostat field. The results do not look correct; in fact, they look very bad. I am unsure if I assigned an incorrect value to a variable.I have also attached the weather data, which is one of the official SAM datasets.I have identified the optimization setting in the Python script with a comment. The variable responsible is called
field_model_type
                28 Jan 2025 13:40         -  28 Jan 2025 13:46        #13840
        Replied by Paul Gilman on topic Heliostat Field Looks Incorrect in PySAM (SolarPILOT Optimization)
        Hi Luis,
First, please update your PySAM to Version 6.0.0. I could not get your script to work in PySAM 5.1.0.
If you run your script, you will get a field with the maximum allowable number of heliostats given the default boundaries for the SolarPILOT optimization algorithm, which results in the receiver under-performing:
Because these default boundaries scale with tower height, you could solve this problem by increasing the tower height. Or, you could use the field optimization method (field_model_type = 0), which will optimize the tower height, receiver height, and receiver diameter using a cost and performance objective:
        Last edit: 28 Jan 2025 13:46  by Paul Gilman.
                29 Jan 2025 01:04         -  30 Jan 2025 17:41        #13841
        by John Anderson
        Replied by John Anderson on topic Heliostat Field Looks Incorrect in PySAM (SolarPILOT Optimization)
        Hi Ricardo,It looks like the issue might be related to the default boundary constraints set for the SolarPILOT optimization algorithm in PySAM. Since these boundaries scale with tower height, the field model may be generating a suboptimal heliostat arrangement, causing the receiver to underperform.Suggested Fixes:
    - Increase Tower Height – Adjusting this parameter should help improve the field layout and receiver performance.
- Use Field Optimization Method – Set 'field_model_type = 0', which allows the system to optimize tower height, receiver height, and receiver diameter based on cost and performance objectives.
        Last edit: 30 Jan 2025 17:41  by Paul Gilman.
- Ricardo
                29 Jan 2025 09:03         -  30 Jan 2025 17:43        #13842
        by Ricardo
        Replied by Ricardo on topic Heliostat Field Looks Incorrect in PySAM (SolarPILOT Optimization)
Thanks for your response. Are you sure that version 6.0.0 of PySAM exists?
In the documentation, I only see 5.1.0 as the latest version: [url] nrel-pysam.readthedocs.io/en/main/versions.html [/url]
The same appears on GitHub:[url] github.com/NREL/pysam/releases [/url]
I have attached the 'requirements.txt' file from my Conda environment to ensure that I'm using the correct version and to avoid any issues when running the script.
I increased the tower height but still encountered the same problem. I changed the height to 300 to confirm that the issue is not related to the height. I also tried using the method with 'field_model_type = 0', but that didn’t seem to work well either.
Could the issue be related to the "No financial" model and the default case 'TcsmoltenSalt.default("MSPTNone")'? Could it be that SolarPILOT requires a variable that is not being assigned?Could you provide me with a 'requirements.txt' file so I can try running my script with your environment? Maybe I’m facing a library compatibility issue.
        Last edit: 30 Jan 2025 17:43  by Paul Gilman.
                30 Jan 2025 17:50                #13846
        Hi Ricardo,
PySAM 6.0.0 is available on PyPi at pypi.org/project/NREL-PySAM/
We've been having issues with Conda, so I don't think it is posted there yet.
And, as you note, the documentation still refers to the older Version 5.1.0.
We'll try to get this sorted -- thanks for your patience during this transition to the new version.
The 'requirements.txt' file that I used for this test has the following line for PySAM:
NREL-PySAM==6.0.0
NREL-PySAM==6.0.0
- Ricardo
                31 Jan 2025 08:23                #13847
        by Ricardo
        Hi Paul and John,Thanks for everything. My issue was the version, everything looks good with PySAM 6.0.0. Thanks again!
