Calculating DNI, DHI and GHI given POA
- Matan
01 Jul 2020 15:30 #8376
by Matan
Calculating DNI, DHI and GHI given POA was created by Matan
I am hoping to figure out a way to convert POA to DNI, DHI and GHI. Looking at the irradproc pySAM module nrel-pysam.readthedocs.io/en/2.0.2/modules/Irradproc.html , it seems like you can convert between the three following irradiance scenarios: [Beam+Diff,Global+Beam, Global+Diff].
Based off the functionality of the "detailed pv" model, the cmod_pvsamv1.cpp and cmod_irradproc.cpp source code, I feel like irradproc should support another scenario, POA only? Is the python wrapped built around a different version of irradproc then is used by pvsamv1?
Best,
Matan Guttmann
Best,
Matan Guttmann
02 Jul 2020 14:54 #8382
Replied by Paul Gilman on topic Calculating DNI, DHI and GHI given POA
Hi Matan,
The irrad_mode input of the pvsamv1 module determines the irradiance components that the model uses as input:
1 = beam and diffuse
2 = total and beam
3 = poa from reference cell
4 = poa from pyranometer
If you set irrad_mode = 3 (or 4) and provide a poa column either in the weather file or in the solar_resource_data table, pvsamv1 will calculate DNI and DHI values from the POA data.
The source code for the POA decomposition model is in lib_irradproc.cpp file, which is confusingly named similarly to the source code for the irradproc module, cmod_irradproc.cpp.
You can use SAM's code generator to generate inputs pvsamv1, set irrad_mode = 3 or irrad_mode = 4 and provide POA data as input. When you run the module, the outputs dn_calc and df_calc should be the calculated DNI and DHI, respectively in W/m2.
2 = total and beam
- Matan
02 Jul 2020 15:05 #8383
by Matan
Replied by Matan on topic Calculating DNI, DHI and GHI given POA
Hello Paul,
Thank you for your reply. Is there a python wrapper for lib_irradproc.cpp ? Ideally I would like to be able to only access the functionality of being able to calculate other irradiance values from any of:
2 = total and beam
Matan
2 = total and beam
Matan
02 Jul 2020 16:16 #8387
Hi Matan,
For now, the only way to decompose POA irradiance into its DNI and DHI components is by running the pvsamv1 module. Unfortunately, there is not a separate "irradproc" module.
If you would like to request one as a new feature, please do so in the SSC GitHub repository:
github.com/NREL/ssc/issues/new/choose
