Error intepreting input value as an integer using Matlab
- Mark Goldsworthy
18 Mar 2020 20:39 #8055
by Mark Goldsworthy
Error intepreting input value as an integer using Matlab was created by Mark Goldsworthy
There seems to be an issue with how values in the input data object are converted to the appropriate types for use in modules.
The value argument of the 'ssc_data_set_number' function is expected to be a single precision variable regardless of the constraint listed for that input in the module.
For example, setting the data value for the number of collectors as 2 is done as:
However, when the swh module is called, the following error is received:
It looks as though it hasn't correctly cast the input single precision variable to an integer.
Any ideas?
cheers
calllib('ssc', 'ssc_data_set_number', data, 'ncoll', single(2) )
fail(ncoll, integer): number could not be interpreted as an integer: 5.30499e-315
Any ideas?
cheers
12 May 2020 09:50 #8187
Replied by Paul Gilman on topic Error intepreting input value as an integer using Matlab
Hi Mark,
We are working to resolve this issue. Please see:
github.com/NREL/SAM/issues/280
We hope to include a fix in the next update to SAM 2020.2.29, hopefully within a week or so.
