tcsmolten_salt example failed in SDK
- Angus King
05 Mar 2015 09:46 #3125
by Angus King
tcsmolten_salt example failed in SDK was created by Angus King
Hi
I might be jumping the gun. I was attempting to run the tcsmolten_salt model with the SAM SDK. I receive an error:
exec fail(tcs_moltensalt): Connections and value settings haven't been programmed for this module yet! (MJW 2104.11.21 time -1
Any timeframe for when it might be available? Meantime I'll use another TCS model
Kind regards
AnGus
ssc version = 41
ssc build info = Unix 64 bit GNU/C++ Feb 2 2015 04:18:49
Log Error: exec fail(tcs_moltensalt): Connections and value settings haven't been programmed for this module yet! (MJW 2104.11.21 time -1
Error [ 0 ]: exec fail(tcs_moltensalt): Connections and value settings haven't been programmed for this module yet! (MJW 2104.11.21
Kind regards
AnGus
ssc version = 41
12 Mar 2015 11:16 #3126
Replied by Paul Gilman on topic tcsmolten_salt example failed in SDK
Dear AnGus,
The tcs_moltensalt module should be working correctly in SDK 2015-1-30. Would you mind [url=mailto:sam.support@nrel.gov?subject=SSC%20tcs_moltensalt%20issue t=_self]emailing me[/url] a copy of the program or script that generated that message?
- Angus King
18 Mar 2015 02:34 #3127
by Angus King
Replied by Angus King on topic tcsmolten_salt example failed in SDK
Paul
On it's way
Kind regards
AnGus
On it's way
Kind regards
AnGus
- Angus King
01 Jul 2015 07:23 #3128
by Angus King
Hi
Still encountering this problem with the 2015-6-30 version. I'm trying to "bootstrap" using this module so it may just be a problem with variable values. Any clues would help.
Kind regards
AnGus
Kind regards
AnGus
08 Jul 2015 14:59 #3129
Hi AnGus,
From my reading of the source code, it looks like this error message is generated when you set the value of receiver_type to a value other than zero. The value of that variable in your CSV file is set to one -- changing it to zero should fix the problem.
That variable is a placeholder for a cavity receiver, which is not currently implemented for the molten salt power tower SSC module -- it can only model an external receiver.
Sorry it took me so long to get back to you on this.
- Angus King
10 Jul 2015 10:05 #3130
by Angus King
Hi Paul
Great. I've just checked and yes receiver type = 1 was the culprit. Now I can progress with fabricating suitable defaults for other variables. No worries on the delay - I have plenty to do
Kind regards
Angus
Kind regards
Angus
