Total (heliostat) field efficiency, definition of
- solargary
16 Jan 2015 02:41 #2950
by solargary
Total (heliostat) field efficiency, definition of was created by solargary
Hi Michael,
is it correct that total field efficiency includes the following losses:
- cosine
- reflectivity
- shading & blocking
- atmospheric attenuation
- availability
- spillage ?
Please confirm / correct. Thank you very much in advance.
Kind regards
Gary
- cosine
- reflectivity
- availability
- spillage ?
Kind regards
Gary
- mwagner
16 Jan 2015 09:30 #2951
by mwagner
Replied by mwagner on topic Total (heliostat) field efficiency, definition of
Hi Gary,
I can confirm your list. The efficiency of each heliostat is the product:
(cosine loss) * ( reflectivity and soiling ) * (shadowing loss) * ( blocking loss ) * (attenuation) * (availability) * (intercept factor - also called spillage).
Mike Wagner
NREL
Mike Wagner
NREL
- solargary
19 Jan 2015 00:44 #2952
by solargary
Replied by solargary on topic Total (heliostat) field efficiency, definition of
Hi Mike,
Thank you very much! It is alweays good when assumptions become facts.
Gary
Gary
- Marwan Mohammad
09 Feb 2016 12:46 #2953
by Marwan Mohammad
Replied by Marwan Mohammad on topic Total (heliostat) field efficiency, definition of
Hello
Is it possible to determine cosine loss or analyse it separately in SAM??
If not, how to detemine it??
10 Feb 2016 10:47 #2954
Replied by Paul Gilman on topic Total (heliostat) field efficiency, definition of
Dear Marwan Mohammed,
The power tower model does not report the cosine loss as a separate loss. The results do show the DNI from the weather file and the field incident thermal power, which should help with your analysis.
