Heat Transfer Fluid Properties
- manishmvs
21 Dec 2011 01:53 #135
by manishmvs
Heat Transfer Fluid Properties was created by manishmvs
Can you please tell me how to feed in the properties of the HTF in CSP project and please help me because i have properties according to ASHRAE Convention i.e for Liquid phase and vapour phase
21 Dec 2011 09:45 #136
Replied by Paul Gilman on topic Heat Transfer Fluid Properties
You can find instructions for specifying a custom heat transfer fluid (HTF) for each of the CSP technologies in Help: From the solar field page, press F1 in Windows or Command-? in Mac OS to open Help, and then expand the "Specifying a Custom Heat Transfer Fluid" section.
Note that you must provide at least two rows of values in the HTF table, and that you must provide values for each of the properties in the units shown in the table's column headings.
I've attached for reference a spreadsheet showing the property tables for each of the HTF included in SAM's default HTF library.
- HasretErcisli
18 Apr 2013 09:17 #137
by HasretErcisli
Replied by HasretErcisli on topic Heat Transfer Fluid Properties
I need the property tables for the Hitec and Hitec XL HTF included in SAM's default HTF library.
Could you please attach the spreadsheet them one more time.
Kind Regards,
Hasret
Kind Regards,
Hasret
18 Apr 2013 09:55 - 07 Jun 2021 10:42 #138
Dear Hasret,
Attachments for replies to forum posts were disabled by the site administrator, so that attachment is no longer visible in my reply below. Sorry about that.
Here is a link to download the file:
The workbook contains a worksheet for each HTF with property values over a range of temperatures.
Last edit: 07 Jun 2021 10:42 by Paul Gilman.
- premcharanraj
02 Jan 2015 06:10 #139
by premcharanraj
Replied by premcharanraj on topic Heat Transfer Fluid Properties
Hi friends,
where can i find the properties of therminol vp-3. Particularly, the Enthalpy calculations ?
Thanks in advance !
Thanks in advance !
- VU LE JOHN
19 Sep 2021 06:27 #10076
by VU LE JOHN
Replied by VU LE JOHN on topic Heat Transfer Fluid Properties
I have attached a link below which contains the properties of
therminol vp-3
www.therminol.com/sites/therminol/files/documents/TF22A_Therminol_VP3.pdf
