Importing measured data file
- Ivan
03 Nov 2022 07:06 #11646
by Ivan
Importing measured data file was created by Ivan
can anyone tell me if I can import data file and run simulation without having some of the climate parameters available (wind direction, snow depth, Tdew) and if yes which data are obligatory to have and which are not?
03 Nov 2022 11:34 #11650
Replied by Paul Gilman on topic Importing measured data file
Hi Ivan,
See the SAM Help topic "Weather Data Elements:"
samrepo.nrelcloud.org/help/weather_data_elements.htm
The "Weather File Formats" chapter has descriptions of weather file formats for SAM's solar, wind, and marine energy models:
samrepo.nrelcloud.org/help/weather_format.htm
- Ivan
30 Jan 2023 01:20 #11882
by Ivan
Replied by Ivan on topic Importing measured data file
Thank you for your answer. I have searched those documents, but I could not find this answer to this question: Is there a possibility to add only GHI to the weather file or I must have at least DHI or DNI also?
30 Jan 2023 17:27 #11887
Hi Ivan,
The table in the Weather Data Elements Help topic that I linked above shows that for the PV models, you need at least two of DNI, DHI, and GHI.
Use the options at the bottom of the Location and Resource page under "Albedo - Sky Diffuse Model - Irradiance Data (Advanced)" to choose which two components you want to use from the weather file:
- Cia
02 Feb 2023 09:11 #11892
by Cia
Replied by Cia on topic Importing measured data file
That's awesome Paul,
Is this feature also available for PVWatts (as opposed to Photovoltaics)? I don't see it in the SAM UI and I couldn't get a reasonable output via PySAM either...
Thanks!
Thanks!
03 Feb 2023 16:54 #11899
Hi Cia,
PVWatts does not support the option to choose irradiance components: It requires a weather file with DNI and DHI components.
That option is only available for the Detailed PV model in SAM, Pvsamv1 in PySAM, or pvsamv1 in the SSC API.
