Import .pan file
- Efigen
04 Apr 2021 13:42 #9423
by Efigen
Import .pan file was created by Efigen
Can you share us your link for import a .pan file (photovoltaic solar module) to be used on SAN app. (MacOS)
05 Apr 2021 16:05 #9428
Replied by Paul Gilman on topic Import .pan file
Hi Efigen,
You can use the" PVsyst OND - PAN to SAM" macro to convert a .pan file to data for SAM:
1. Create or open a Detailed PV case in SAM.
2. Click Macros under the Simulate button.
3. Choose the macro from the list and click Run macro at the top of the SAM window.
- lukereed
11 Dec 2024 08:21 #13673
by lukereed
Replied by lukereed on topic Import .pan file
This functionality has been very helpful within SAM. Is there an equivalent exposure within pysam?
Luke
Luke
11 Dec 2024 10:11 #13675
Hi Luke,
PySAM does not have built-in tools for reading module parameters from PVsyst .pan files.
You could write your own Python script based on SAM's macro (which is written in the LK scripting language ): github.com/NREL/SAM/blob/develop/deploy/runtime/macros/Flat%20Plate%20PV/PVsyst%20OND%20-%20PAN%20to%20SAM.lk
If you do that, feel free to contact me if you run into any problems. You might also consider making a code contribution to the PySAM project by adding to the PySAM tools collection: github.com/NREL/pysam/tree/main/files
- lukereed
11 Dec 2024 11:15 #13678
by lukereed
Appreciate the prompt response and for pointing me in the direction of the underlying code for the macro. If I do create a python script to parse PAN files I'll certainly add it as a code contribution to the PySAM project.
Cheers,
Luke
Cheers,
Luke
- Oscar Chaves
05 Apr 2025 15:02 #13979
by Oscar Chaves
Replied by Oscar Chaves on topic Import .pan file
I need this inverter be uploaded: EG4-FLEXBOSS21 HYBRID INVERTER. How this is done?
