Parametric Analysis on PV System Size or DC-AC Ratio
29 Aug 2019 11:28 - 29 Aug 2019 11:41 #7633
Parametric Analysis on PV System Size or DC-AC Ratio was created by Paul Gilman
For the Detailed Photovoltaic model, before you run a parametric analysis on Desired DC-AC Ratio (desired_dc_ac_ratio) or Desired Array Size (desired_size), be sure to check Estimate Subarray 1 configuration on the System Design page. Otherwise when you run a parametric simulation, it will appear that changing the DC-AC ratio or system size has no effect on results.
For example, here are results for a parametric simulation on system size without checking the estimate Subarray 1 configuration option, where you can see that the annual energy and net present value do not vary with the desired sytem size:
By adding the System Nameplate DC Rating (nameplate_dc_rating) output to the list, you can see that SAM did not vary the actual size of the system:
Now, if we rerun the parametric simulation after checking Estimate Subarray 1 configuration on the System Design page, we get the results we expected:
If you are modeling a system with more than one subarray and want to do a parametric analysis on system size or DC-AC ratio, then you will have to adjust the numbers of modules in each subarray, and possibly the number of inverters:
Subarray 1 modules per string (subarray1_modules_per_string)
Subarray 2 modules per string (subarray2_modules_per_string)
Subarray 3 modules per string (subarray3_modules_per_string)
Subarray 4 modules per string (subarray4_modules_per_string)
Number of parallel strings 1 (subarray1_nstrings)
Number of parallel strings 2 (subarray2_nstrings)
Number of parallel strings 3 (subarray3_nstrings)
Number of parallel strings 4 (subarray4_nstrings)
Number of Inverters (inverter_count)
Last edit: 29 Aug 2019 11:41 by Paul Gilman.
- hhundt
11 Sep 2019 15:52 #7662
by hhundt
Replied by hhundt on topic Parametric Analysis on PV System Size or DC-AC Ratio
Perfect post that answers why I have been struggling with parametric results after modeling systems with all subarrays checked and specified.
One follow up and clarification:
If I want to keep subarrays checked and the module distribution ratio--is the only away to check different total array size via parametrics to figure out distribution for each subarray at each possible array size I want to test the financials around? I assume that is what you're specifying at the bottom but I want to double check before I spend the time calculating each string and module number for each sub for each array size I want to test.
Thanks!
Thanks!
11 Sep 2019 16:23 #7663
Replied by Paul Gilman on topic Parametric Analysis on PV System Size or DC-AC Ratio
Yes, your follow-up comment is correct. For a system with more than one subarray, you'll have to set the number of modules per string and strings in parallel (and possibly number of inverters) for each parametric scenario.
- hhundt
12 Sep 2019 15:15 #7665
by hhundt
Thanks for the confirmation. One followup question:
Can one just enable subarray variables in parametric quick-setup?
PV System Design/Enable Subarray 2 (subarray2_enable)
PV System Design/Enable Subarray 3 (subarray3_enable)
PV System Design/Enable Subarray 4 (subarray4_enable)
Thanks.
Thanks.
13 Sep 2019 14:36 #7666
Yes. For example set subarray2_enable = 1 to enable subarray 2, and subarray2_enable = 0 to disable it.
- Craig Pickup
18 May 2021 00:36 #9598
by Craig Pickup
Replied by Craig Pickup on topic Parametric Analysis on PV System Size or DC-AC Ratio
Hello, I am trying to narrow down the optimal solar PV system size but am having issues with the desired DC-AC ratio in parametric analysis.
I have checked the estimate subarray 1 configuration as suggested but this does not change the annual energy output.
Besides the mentioned checkbox, is there something else that could be stopping this?
