Collector tilt and azimuth
  • sebastian
02 Jul 2012 06:44 #671 by sebastian
Collector tilt and azimuth was created by sebastian
Could anybody tell me what values are the correct for the collector tilt and azimuth in an concentrating solar thermal plant CSP Though in Spain?
Or is there any website in which I could get this information?
Thank you very much!
Best regards.
05 Jul 2012 15:29 #672 by Paul Gilman
Replied by Paul Gilman on topic Collector tilt and azimuth
The SolarPaces and NREL Troughnet websites are both good starting points for researching information about CSP systems.
In general, you can use the default tilt and azimuth values of zero for the CSP models unless you have a reason to change them. Those values represent a system with horizontal collectors oriented N-S so that they rotate from east in the morning to west in the evening.
  • sebastian
09 Jul 2012 05:49 #673 by sebastian
Replied by sebastian on topic Collector tilt and azimuth
I still have a doubt remaining. Does it affect the value of tilt and azimuth if my collectors are orientated E-W instead of N-S??
In that case, what would be the values of tilt and azimuth for E-W orientation??
Thanks a lot Paul,
Best Regards.
09 Jul 2012 13:08 #674 by Paul Gilman
For the parabolic trough models, you can use the tilt and azimuth variables to specify a field with collectors that are oriented E-W. After running simulations, you can plot graphs of the solar angles and collector incidence angle to see the effects of different collector orientations: On the results page, click Base Case Time Series and choose the type of graph and variables to plot.
  • Franilena
05 May 2015 03:36 #675 by Franilena
Replied by Franilena on topic Collector tilt and azimuth
I understand that for a solar field oriented N-S the tilt and the azimuth angle must be equal to zero, but as Sebastian asked, for a solar field oriented E-W what should be the correct angles?
Franilena
05 May 2015 11:36 #676 by Paul Gilman
Dear Franilena,
For the parabolic trough models, a collector azimuth angle value of zero (on the Solar Field page) is for a N-S field. To rotate the field by 90 degrees, you would change the azimuth angle to either 90 degrees or -90 degrees. If you use a tilt angle of zero, it should not matter which way you rotate the field. If the tilt angle is not zero, then for an azimuth angle of zero, the lower end of each collector is nearest the equator, and for 90 degrees, the lower end is nearest the western horizon.
