與資源高度相比,無法檢查輪轂高度-風力渦輪機
  • isakhar
02 Oct 2017 01:04 #5767 by isakhar
Dear SAM Team
I am trying to simulate Wind using SAM version 2017.1.17 but I get the notification said "Could not check hub height compared to resource height. This may indicate a problem with your weather file".
I have changed my file to the Windows (CR/LF) or Unix (LF) format but I still face the error.
Here I attached my file (80m.srw). Please take a look.
My appreciate for some advices.
Soares
02 Oct 2017 16:16 #5768 by Paul Gilman
Dear Soares,
The problem appears to be with the atmospheric pressure data. SAM expects the data to be in units of atmosphere, with values on the order of 1. The values in your file are on the order of 10000.
  • isakhar
02 Oct 2017 18:29 #5769 by isakhar
Dear Mr.Paul Gilman
Ah, I got it. Now it is working.
Thank you very much for the help.
Soares
  • isakhar
05 Oct 2017 22:59 #5770 by isakhar
Dear Mr.Paul Gilman
I have data of 80 meter wind speed above mountain area. What is the best choice of wind performance model in SAM that I should use ?
Thank you for your some advices.
Soares
06 Oct 2017 11:58 #5771 by Paul Gilman
Dear Soares,
You can use either option on the Wind Turbine page. You can choose a turbine from the library if you have a specific turbine in mind. If you are interested in trying different turbine designs, you can enter design parameters instead.
  • Bo-Xian Huang
03 May 2023 23:45 - 04 May 2023 15:17 #12099 by Bo-Xian Huang
Dear SAM Team:I'm also trying to simulate Wind Power by using SAM version 2022.11.21, and I got the notification "Could not check hub height compared to resource height. This may indicate a problem with your weather file".I attached my file, Appreciate for your some advices.Best regards,Pamela.
Last edit: 04 May 2023 15:17 by Paul Gilman.
