Updating wind turbine files
- tam.hunt@gmail.com
                15 Nov 2015 15:37                #3913
        by tam.hunt@gmail.com
        Updating wind turbine files was created by tam.hunt@gmail.com
        Hello, do you plan to add new wind turbine data to the default library soon? For example, GE has a number of new turbines that aren't in the database.
                16 Nov 2015 12:33                #3914
        Replied by Paul Gilman on topic Updating wind turbine files
        Dear Tam,
We do not currently have plans to update the wind turbine library, but hope to get support to do so in the future.
If you have power curve for turbines that you would like to model in SAM, you could add it to the library yourself. The library is a CSV file called "Wind Turbines.csv" and is stored in the "libraries" folder in your SAM installation. You can see how the data is formatted for the other turbines and add your data for each new turbine as a row at the end of the file. Note that the power curve data for wind speed (m/s) and power (kW) are each in a single cell with values separated by the pipe "|" symbol.
                20 Nov 2015 16:47                #3915
        Replied by tam.hunt@gmail.com on topic Updating wind turbine files
        Great, thanks Paul, this is helpful.
                20 Nov 2015 16:49                #3916
        I'm not finding that file. Is that for the Mac version too?
                23 Nov 2015 09:21                #3917
        Dear Tam,
Here are instructions for finding the installation folder on a Mac. You should see the wind_resource folder under "Contents:"
sam.nrel.gov/node/69223
                23 Nov 2015 22:49                #3918
        Great. I found it and modified it but it won't let me save it in the libraries folder. Can I make SAM see that file stored somewhere else or is there a setting I need to change to make it saveable in the correct folder?
