CSP
- R M
21 Oct 2015 04:48 #3842
by R M
CSP was created by R M
I want to do parametric analysis for tower height by fixing the power output from the power tower (i.e. for 1 MW electrical output) and radius of the heliostat field (i.e for radius = 200 meters) for different locations in India. I am using SAM Version 2015.6.30.
How to do this kind of analysis in SAM ?
With Regards
Mohit
With Regards
Mohit
21 Oct 2015 12:05 #3843
Replied by Paul Gilman on topic CSP
Dear Mohit,
You can use SAM's parametric simulation feature to run a set of simulations on different weather files. For the power tower model, you may want to check the "Always layout automatically" and "Always optimize" boxes on the Heliostat Field page so that SAM calculates the optimal field layout for each location. On the other hand, if you want to fix the field layout, then you should clear those boxes.
To run a parametric simulation on location, you should add the Location variable to the list of input variables. Before you do that, you will need to download weather files for the locations in India, and then on the Location and Resource page, click "Folder settings" to add the folder that contains the files to the list of folders SAM searches for weather data. That will ensure that your files appear in the list of available input variables for the parametric simulation.
- R M
22 Oct 2015 05:08 #3844
by R M
Replied by R M on topic CSP
Thanks Paul.
Can you give me any hint about how SAM calculates tower height for any location and required energy out from the field ?
With Regards
Mohit
With Regards
Mohit
22 Oct 2015 14:48 #3845
Dear Mohit,
Please see the "Heliostat Field Design" topic in SAM's Help system, and the "Using SolarPILOT for Field Optimization" section of the "Heliostat Field" topic.
- R M
24 Oct 2015 04:38 #3846
by R M
Thanks Paul
