How does SAM calculate the irradiation on a tilted and oriented plan for the PV systems?
- RaquelF
27 Apr 2015 03:41 #3258
by RaquelF
How does SAM calculate the irradiation on a tilted and oriented plan for the PV systems? was created by RaquelF
Hi!
I wanted to know how does SAM exactly calculate the irradiation on a plan with given tilt and azimuth. I've tried to understand with the 'Help' option but I only found the way that SAM calculates the beam irradiation initially to use as data.
Hopefully someone could help me to understand this.
Thank you in advance,
Raquel
Raquel
27 Apr 2015 12:10 #3259
Replied by Paul Gilman on topic How does SAM calculate the irradiation on a tilted and oriented plan for the PV systems?
Dear Raquel,
Please see Chapter 6 of the SAM Photovoltaic Reference Manual available from the Performance Model Documentation page for a detailed description of the calculations. This is the final draft of the manual and should be published as an NREL publication soon.
- RaquelF
01 May 2015 06:49 #3260
by RaquelF
Replied by RaquelF on topic How does SAM calculate the irradiation on a tilted and oriented plan for the PV systems?
Thank you very much!
I was wondering if you could explain one expression in Chapter 5. Just before the first expression (5.1), you say that the AOI is a function of sun azimuth angle, sun zenith angle, etc. But the sun azimuth angle is not a part of that equation, why?
Another doubt that I have, and maybe it a little stupid question, if the zenith angle is (PI/2-solar altitude) why do you use cos(Z) and not sen(solar altitude)?
Raquel
Raquel
01 May 2015 11:23 #3261
- RaquelF
12 May 2015 09:19 #3262
by RaquelF
I have another question. In equation 6.2 why don't you use the diffuse irradiance in the horizontal?
Thank you in advance!
12 May 2015 09:44 #3263
Equation 6.2 in Section 6.1 is for the beam irradiance on a horizontal surface, so it uses the beam normal irradiance from the weather file rather than the diffuse irradiance.
The incident diffuse irradiance equations are described in Section 6.2.
