Troubleshooting simulation errors with a parametric analysis can be tricky because it's hard to identify which of the several simulations is causing the error.
You might start by looking at the end points of your parametric inputs. For example, to see if the simulation fails with small solar multiple values. Try duplicating your case, and in the copy of the case, disable the parametric analysis option, and on the Solar Field page, set the solar multiple to the smallest value you included in the parametric values, and perhaps with the largest storage capacity. If the simulation crashes with those values, then the problem might be that the solar field at that solar multiple value is too small for the system you specified.
