Standalone Battery Modelling using SAM
  • Sachin Kumar Pandey
27 Jul 2021 05:27 #9878 by Sachin Kumar Pandey
Standalone Battery Modelling using SAM was created by Sachin Kumar Pandey
Dear SAM team,
Could please guide on how to proceed for modelling standalone battery storage financial analysis?
Please provide your input as i am new to SAM.
Thank you!!!
27 Jul 2021 12:39 #9879 by Paul Gilman
Replied by Paul Gilman on topic Standalone Battery Modelling using SAM
Hi Sachin,
You can find a brief description of how to model a battery-only system here:
sam.nrel.gov/battery-storage.html
27 Jul 2021 22:20 - 28 Jul 2021 14:34 #9885 by Sachin Kumar Pandey
Replied by Sachin Kumar Pandey on topic Standalone Battery Modelling using SAM
when i am trying to use standalone battery model with grid charging with default values. It is giving negative energy.
Request for your input. Thank you!!!
Last edit: 28 Jul 2021 14:34 by Paul Gilman.
28 Jul 2021 14:36 #9887 by Paul Gilman
Hi Sachin,
Could you attach a copy of your .sam file so I can investigate?
Also, please attach any screenshots as an image file (.jpg, png, bmp, etc) and then insert it into your message. Otherwise the image does not render properly.
28 Jul 2021 21:26 #9892 by Sachin Kumar Pandey
Test.SAM
I have attached the .sam file in the drive link. Thank you for your support.
30 Jul 2021 08:41 #9895 by Paul Gilman
Hi Sachin,
Thank you for sharing your file.
The "annual energy" value is the sum of the hourly or subhourly kW delivered to the grid. For a standalone battery that charges from the grid, the total energy delivered by the battery to the grid over a year must be less than the energy delivered to the battery from the grid because of roundtrip efficiency losses: The battery dissipates heat as it charges and discharges. So, I would expect annual energy to be negative.
You might want to try the manual dispatch option so you can control when the battery charges and discharges.
Also, you might consider installing the latest version of SAM to get the newest updates to the battery model.
