Total system flow rate in Solar water heating
  • Afin Fadzlin
  • New Member
  • New Member
19 Apr 2021 03:53 #9474 by Afin Fadzlin
Total system flow rate in Solar water heating was created by Afin Fadzlin
Hi, I just want to know if the total system flow rate in solar water heating applies to all-glass evacuated tube collectors as well? Also, is there a way to simulate thermosyphon solar water heating system? Cause there seems to be options for separate tank solar water heater only. Appreciate any help on this, thanks.
  • Paul Gilman's Avatar
19 Apr 2021 16:51 #9477 by Paul Gilman
Replied by Paul Gilman on topic Total system flow rate in Solar water heating
Hi Afin,
From the Solar Water Heating model description in Help:
"The solar water heating (SWH) model represents flat-plate solar collectors with a one tank water or glycol storage system and a auxiliary electric heater. "
You can find more information about the model in Help, and a detailed description in DiOrio, N "Technical Manual for the SAM Solar Water Heating Model" (Draft) available at sam.nrel.gov/solar-water-heating.html .
