Hi Francisco,
As of SAM 2020.2.29, the Physical Trough model uses a new dispatch control algorithm in place of the old manually controlled method. See the Help topic for the System Control page for a description of the algorithm. It is also described in Wagner M (2018) "Optimized Dispatch in a First-principles Concentrating Solar Power Production Model" available under "Power Tower" on the CSP publications page:
If you have a reason to use a model with the old dispatch method, you can download SAM 2018.11.11.
