Parabolic trough for further heating geothermal water
  • Numan Demirdöğen
  • New Member
  • New Member
17 Mar 2021 08:25 #9378 by Numan Demirdöğen
Parabolic trough for further heating geothermal water was created by Numan Demirdöğen
I am trying to simulate an off-grid system which consists of a geothermal power plant and a parabolic trough. Parabolic through is going to be used to increase the temperature of geothermal water. Thermal oil is going to be used as heat exchange fluid and a thermal storage tank will be deployed. I want to compare this system with a scenario in which I use electricity for increasing the temperature of geothermal water. I want to choose best performance model for what I want to do. As far as I understand, only Parabolic Trough - Heat: LOCH Calculator performance model can serve me. Could you help me to determine which performance model is best for my use case?
Solar Water Heating -> Distributed -> Residential and Commercial Owner uses glycol or water as working and test fluid.
Parabolic Trough Physical and Emprical assume generating electricity by using turbine.
Thank you in advance.
  • Paul Gilman's Avatar
17 Mar 2021 23:06 #9381 by Paul Gilman
Hi Numan,
SAM is not designed to model this kind of system, but I think you are correct to use the Parabolic Trough - Heat model for this application.
Note that it models a constant heat sink power. You cannot define a heat sink power that varies with time.
  • Numan Demirdöğen
  • New Member
  • New Member
05 Apr 2021 08:24 #9424 by Numan Demirdöğen
Replied by Numan Demirdöğen on topic Parabolic trough for further heating geothermal water
@Paul,
Thank your for answering my question! If I am not being rude by asking this question, do you know any other software that can help me?
05 Apr 2021 21:51 #9425 by Paul Gilman
Hi Numan,
I am not aware of such a model, but if anyone else is, please let us know!
