I assume you are asking about one of SAM's photovoltaic models. The flat-plate PV, PVWatts, and High-concentration PV models all account for the effect of temperature on the module's performance, and use ambient temperature and wind speed data from the weather file to adjust the array's performance accordingly.
I'm not sure about the limits you describe. Do you have weather data with these extreme values?
You can read about the temperature correction calculations for two of SAM's PV module models, the Sandia and simple efficiency models in SAM's Help system in the
Module topic
