Solar Field Initial temperature
  • sidom
  • Junior Member
  • Junior Member
10 Dec 2012 16:53 #1067 by sidom
Solar Field Initial temperature was created by sidom
Hello Paul,
I am working with SAM Empirical model. Does solar field initial parameter works properly? I am trying to change it and find the difference in the first hour of the simulation but this parameter does not change. What is it about?
Thanks in advance
  • Paul Gilman's Avatar
14 Dec 2012 16:05 #1068 by Paul Gilman
Replied by Paul Gilman on topic Solar Field Initial temperature
We are investigating this now, and I will follow up as soon as I have more information.
  • sidom
  • Junior Member
  • Junior Member
17 Dec 2012 09:11 #1069 by sidom
Replied by sidom on topic Solar Field Initial temperature
Thank you Paul.
It would be grateful if I had a response back.
19 Dec 2012 16:27 #1070 by Paul Gilman
There is a bug in the Empirical Trough model that causes the initial field temperature not to have an impact on the results. However, this only affects the system's output in the first hour of 8,760, so it does not have a significant impact on the overall results.
We will include a fix to this problem in an interim update.
